smelling gasoline,leaking?
Old Jul 24, 2005 | 12:42 AM
gtzy's Avatar
gtzy
Default smelling gasoline,leaking?
With the door down and my 98 parked inside,my garage has a strong smell of gasoline.It is strongest in the left rear wheel area. There is no signs of leakage on ground or around the left pump.Before I pull the inner wheelhouse liner to check the filler tube and vent pipe I wanted to ask if anyone has any ideas of what might be the source of this gas odor?
Old Jul 24, 2005 | 01:21 AM
Viprklr's Avatar
Viprklr
I had the same problem. Turned out to be the filler tube (or whatever you call it). It wouldn't leak at any other time than when I filled up the car. Took several trips to the dealer to convince them of the problem.
It may be something else, but I would check to see if it happens during fill-up.
Matt
Old Jul 24, 2005 | 12:02 PM
gtzy's Avatar
gtzy
I replaced the fuel filter myself in April,so I thought I would check there 1st,the outlet side showed some wetness,,upon pulling on the outlet line it really started dripping and line released from the filter,I thought I had the line firmly seated in the filter when I installed it,but apparently not..reinstalled the line in the filter and gave it a tug to check..given this filter is directly above the left exhaust pipe,it could have been a disaster.
To smelling gasoline,leaking?
