Car wouldn't start until added fuel
Old Jul 25, 2005 | 10:55 AM
NealB's Avatar
NealB
Default Car wouldn't start until added fuel
Got a weird one happened to me and was wondering if someone knew the cause.
Was driving the car really hard for quite a while, and got a low fuel light and a trans temp warning at the same time. The gas gauge had been reading about one quarter, and when the low fuel message appeared on the DIC, the gauge dropped to on the peg empty.
Stopped to get fuel, shut off the engine and when the gas pump wouldn’t take my credit card, went to restart to try a different pump.
But, had what appeared to be the dreaded steering column lock. (I know now after reading the FAQ that it wasn’t that.) The steering wheel wouldn’t move no matter how hard I moved it back and forth, and the key wouldn’t turn in the ignition.
Got the attendant to manually allow me to pump fuel, and after adding fuel, the car was normal.
What was that about.
Old Jul 25, 2005 | 03:49 PM
Ginzo's Avatar
Ginzo
Was the key removed prior to your attempt to fuel the car? If so and when the key was put back in and would not turn this would account for the wheel being locked. Now if this is the case putting fuel in the car would not have any effect on getting the key to turn in the ignition.
Old Jul 26, 2005 | 10:20 AM
NealB's Avatar
NealB
thanks for the input but not sure I understand
yes, the key was removed after shutting off the engine
then when key reinserted, wheel was locked and key would not turn at all
no matter what bad words I said or how hard I tried to turn either the wheel or key
it may have been that adding fuel had nothing to do with things unlocking, but I'm still puzzled
Old Jul 26, 2005 | 01:39 PM
college_guy's Avatar
college_guy
Sounds to me that your column locked up (how it should) when you pull the key out! Just have the move the wheel left or right and the key should go in just fine! This happens on all cars with column locks!
Old Jul 26, 2005 | 02:09 PM
NealB's Avatar
NealB
did that a bunch, gently then as hard as I could
no impact
key went in fine, just couldn't turn it at all
Old Jul 26, 2005 | 03:01 PM
college_guy
no impact
And you said you tried shouting at it???
To Car wouldn't start until added fuel
