Slow Leak in Tire?????
On trips where the tire is heated up and runs everyday or long term, I have no loss. Went to the CF CI in BG and did not have to add any air for a week.
Someone told me that it could be I have to have the bead reseated, or if could be the O-Ring around the stem.
Question???Is the O-Ring located on the outside of the tire or on the inside?
Anyone had this problem, any Suggestions??
Thanks in advance..
Thanks in advance..
I believe the O-ring is inside.
EEL
-=Rick
And I will add - get a small bowl, a brush, and some dish soap (keep it away from your paint of course). Put some soap (just a little) and water in the bowl and start brushing areas. If the leak is that big you "should" be able to find it. Check around the valve stem (take the cap off and try the valve too). Good luck (mine have always turned out to be nails or beer bottles - yes that was beer bottle
All our fellow members above have kindly suggested important clues to help you discover the possible reason for your tire leak. Again, do check the o-ring and hex nut. These fasteners must be secured and screwed down tightly. Also, check the actual inner tire valve stem core. This small inner steel core located inside the valve stem may be loose, damaged, and/or, actually missing. In fact, this was the culprit to one of my very notorious tire leaks.
Damaged or faulty inner valve stem cores are easily repaired by simply unscrewing the faulty inner valve core out and replacing it at a local tire shop. Furthermore, make sure that the valve stem cap still has a viable inner cap ring in good shape. The cap to the valve stem make a good and tight air lock seal that assists in preventing insidious leaks. Moreover, if the inner cap ring surface appears damaged, excessively occluded and corroded, then replace the cap.
And, in an effort to share the importance of the integrity of the valve stem cap ring inside the cap: Recently, I had a tire replaced at local tire servicer. The tire tech forgot to replace the inner valve stem core that he had in mind to replace. Now, had it not been for the tight seal provided by the valve stem cap ring, the tire would have gone flat while in traffic.
Luckily, I happened to make it a point to ask him if he had changed the core before I backed out the car. The tech visibly paled to a puce green when he removed the cap and noticed the empty valve stem and missing inner valve stem core. The tire immediately leaked out all the air under pressure, and, was flat in seconds. Hope this info helps.
Best Wishes,
Eden
I would de-mount the tire clean the rim bead very well, check for the presence of any stickers or other foreign debris and re-mount. HTH
I printed everything out and will start with the small stuff and work up to the larger as I go. I'll keep you all posted.
Love the car, but beginning to hate that left front tire.
I suggest pulling the old tires off and just taking a look, i did and it suprised me
I purchased a new set of aluminum wheels for my car hauler and one of the tires kept going down. I could not find a leak anywhere in the rubber or where it sealed to the rim. I had trouble getting my wheel under water and ended up filling my wheelbarrow with water and using it. I was able to get the tire and wheel up to the hub under water and just rotated it slowly until I found my leak. You guessed it, in the middle of the rim on the inside there was a pin hole and air was leaking. The manufacturer replaced it and would not allow me to purchase the defective rim to use as a spare. They insisted it had to be destroyed.
Use the water test, it works every time.
GUSTO
GUSTO
I seen other posts here that a few other guys had something similar to this too. Go figure.
GUSTO
