Marker Lights?!?
Old Jul 26, 2005 | 03:29 PM
Biggieflan's Avatar
Biggieflan
Default Marker Lights?!?
Well I've seen a few vette out on the road with the right marker light in the front bumper out. I always wondered why it was always the right side. Now my front bumper marker light went out, when I attempt to put the blinker the clicking noise on the inside is twice as fast. Should I just replaace the bulb and get on with it? Or is it more complicated than that?
Old Jul 26, 2005 | 04:09 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Bulb is 194.
Old Jul 27, 2005 | 01:28 PM
Biggieflan's Avatar
Biggieflan
I'm Sorry, kinda new to the forum. You said the bulb is 194? What does that mean? Thanks.
Old Jul 27, 2005 | 01:47 PM
LRD VDR's Avatar
LRD VDR
That is the bulb number that you will need to know when you go to the parts store.
Shahram
Old Jul 27, 2005 | 01:52 PM
gredmer's Avatar
gredmer
My right side went too.
Old Jul 27, 2005 | 09:55 PM
Biggieflan's Avatar
Biggieflan
Well, its sound like I just have to replace the bulb and everything should be fine. Thanks for the part number.
Old Jul 28, 2005 | 12:23 PM
corvetterookie's Avatar
corvetterookie
3rd Gear
Default marker lights
How do you get to the bulb in the right front?
Old Jul 28, 2005 | 01:13 PM
rbarley's Avatar
rbarley
I've had this same problem and you can resolve it by replacing the marker light. I bought two for $5.00. The proper way to change the bulb isn't real simple. Jack up the right front enough so you can get to a black plastic service panel located in front of the tire. After you take the panel off, you can reach in there and remove the bulb for replacement. Now, here's another way, but not by the book. Reach into the front air duct in the front bumper and push aside the plastic duct work to the right and you can probably access this bulb. Takes small hands in most cases and the plastic flexes pretty good in hot weather. It's not by the book, but works for some people.
To Marker Lights?!?
