I want to service my rear diff but i need some help with the location of the fill and drain plugs and if there is any tricks and special tools need to do this job i will be useing all oem fluids to do the refill so not to have any warrenty problems in the future.
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
I've never done this, so I'm repeating whats in the service manual.
Draining Procedure:
1. Raise and support the vehicle.
2. Clean any dirt from around the differential
3. Remove the drain plug and washer from the differential.
4. Drain the fluid.
The drain plug is on the bottom of the differential towards one side.
Filling Procedure:
1. Install the drain plug and washer to the differential. Tighten to 26lb ft or 35N-m
2. Clean any dirt from around the differential fill plug.
3. Remove the fill plug, lubricant tag, and washer from the differential.
4. Fill the differential with fluid:
Fill with synthetic axle lubricant, GM part# 1237826. Add approx 118ml (4oz) limited slip differential lubricant additive, GM Part# 1052358
5. Check the fluid level to ensure it is even with the bottom of the fill plug hole to no lower than 6mm (0.25in) below the opening.
6. Install the fill plug, lubricant tag, and washer to the differential. Tighten the fill plug to 26lb ft or 35N-m.
7. Lower the vehicle.
The fill plug is on the side of the differential and kinda looks like a torx bolt from the picture.
