Help Please ! Driveline vibration?
Old Jul 27, 2005 | 05:30 PM
patrickboyle's Avatar
patrickboyle
Default Help Please ! Driveline vibration?
You know you have a problem when your wife says "what's that rumbling I feel in my seat" ? I've noticed a "vibration" at highway speeds on smooth roads. It's in the rear of the car & I don't think it's a tire. Any ideas ? Hard to describe, the car is vibe free & then the vibe comes in & goes away in that sequence.
Old Jul 27, 2005 | 05:42 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
have you swapped gears?
Old Jul 28, 2005 | 09:22 AM
patrickboyle
No, the car is stock with 3.15's. Gears are planned though..
Old Jul 28, 2005 | 10:40 AM
Mike04's Avatar
Mike04
Does the vibe happen at a certain RPM or is it MPH related?
Old Jul 28, 2005 | 11:30 AM
patrickboyle
Mph related...an example...after 50mph there's the vibe then not for a few seconds then the vibe..then not. I feel like it's driveshaft or joint related but not sure.
Pat
Old Jul 28, 2005 | 12:10 PM
woosch's Avatar
woosch
What year car do you have? It could be the rubber bushings going bad or a number of us here in Atlanta have found that the bearings in the torque tube go bad...
Old Jul 28, 2005 | 01:35 PM
Pumba's Avatar
Pumba
Patrick,
If the vibration phases in and out above 50 mph and is coming from the rear of the vehicle, I would take a look at the tire-wheel combination.
Tires have a force called Radial First Harmonic that can phase in and out depending on the relationship of the left-side tire to the right-side tire.
Also, tire imbalance increases with mileage accumulation. Check for loss of a balance weight, or if you need to have the tire-wheel assemblies rebalanced.
Old Jul 28, 2005 | 01:46 PM
TVSKIP's Avatar
TVSKIP
check your front tires for inside wear. I have this problem on my 2000 vert. If I run the tire pressure at 30 lbs, I feel a rhythmic sensation that comes and goes about every 3-4 secs at 70 or so mph. If I raise the pressure to 32-33 lbs, smooth as glass. The inside of my fronts are badly scalloped. They're OE tires with 42,000 miles! I cant complain about wear at that mileage. Alignment was checked, wasn't far off. Replacing tires next week, Hope this helps....SAVE THE WAVE..
Old Jul 28, 2005 | 02:40 PM
patrickboyle
You guys are making me feel better. I'll check for a missing wheel weight & check tire pressure again. I beleive the tires were at 29psi warm on the way home yesterday. Woosch: the car is an '03 with 3000 miles on it.
My dad runs an alignment shop in Appleton so I can "road force" balance If I have to. Thanks for the tips
Old Jul 28, 2005 | 04:09 PM
JoshVette's Avatar
JoshVette
I would think if it was the drivetrain, it would be more RPM based, but since it MPH based and coming from the back it's wheel related.
I had a surging noise and feeling that was vibrating my car too and it turned out to be the wheel hub bearings.
Mine did it around 50mph+ and was real bad at 70mph+
You might try shifting it down at 30 and get your RPM's up for a minute and see how it sounds and feels, might help determine if it's connected to the RPM's???
Old Sep 5, 2005 | 11:15 PM
fsa00120's Avatar
fsa00120
I was just wondering if you have solved your vibration problem.
I have a 99 6 speed - 34000 miles with a new set of Goodyear run flats that was installed when I bought the car. The dealer cannot find the harmonic vibration that I can hear and feel in the gas pedal at 40MPH + on smooth roads. It is real noticable that 70MPH on a smooth Interstate road.
Regards,
Harry J Brown
hbrown@ma.rr.com
Old Sep 6, 2005 | 12:13 AM
DPG's Avatar
DPG
St. Jude Donor '06
i think i have the same problem. buttttt its at any speed cruising. It is that vibe in and out. I guess its time to check the wheel weights from what you guys are sayin.... i hope that the weights are it cause that would be easy...
Old Sep 6, 2005 | 12:19 AM
tolk's Avatar
tolk
Easily could be a rear wheel/hub bearing. I have the same problem and have replaced both rear axles/cv joints. I think the C5 wheel hubs have the potential to wear out rather quickly. Mine doesn't show up until about 40 mph and goes away when I make a left turn. Have someone else drive and lay in the back and listen, the noises can be decieving from the front seat. Mine turned out to be a wheel hub/bearing.
Old Sep 6, 2005 | 12:38 AM
Z11409's Avatar
Z11409
Try moving tires from side to side--GY runcraps are known for hard spotting
Old Sep 6, 2005 | 12:17 PM
I brake for nothing's Avatar
I brake for nothing
**** I have this and have been trying to track it down. I replaced my pass side hub assembly by recommendation with no effect.
It comes in at 120 - 130 kph gradually getting worse to about 145 kmph and then smoothing out a bit. Its just as described above , a harmonic vibration moving through the driveline. Long burst , then gone. I cant tell if its front to back or back to front feeling but its nasty.
I have drag radials out back that need to be replaced so Im hoping that helps.
To Help Please ! Driveline vibration?
