98 fuel system help
Old Jul 28, 2005 | 01:11 PM
smittydog's Avatar
smittydog
Default 98 fuel system help
My 98 is having a mid to upper RPM surge/miss from about 4k to 6.5k. Easy driving around town everthing is fine under heavy acceleration my problem starts to appear. The car has 75K on it with h/c. I will be replacing the fuel filter soon which is supposed to be on my rear frame rail. Along with that i'll be checking my fuel pressure(under load) and wondered how the fuel pressure regulator works and lets fuel return to the tank. Any thoughts or information would be appreciated.
Old Jul 28, 2005 | 01:55 PM
Silver98's Avatar
Silver98
The fuel filter is on the driver's side, nested up above the frame rail forward of the rear wheel. Looked real easy to change on the lift.
Old Jul 28, 2005 | 03:14 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Fuel Filter
________________________________________ ____________________
[Silver98]The fuel filter is on the driver's side, nested up above the frame rail forward of the rear wheel. Looked real easy to change on the lift.
75,000 miles and not sure when it was changed last?.....That's a good place to start. You will need a special tool (auto zone,napa,pep boys) that you slip over the fuel line, push into the filter to release the fingers that hold the fuel line to the filter. Good luck
Old Jul 28, 2005 | 03:37 PM
smittydog's Avatar
smittydog
Is that the same little tool used for removing the fuel lines from the fuel rails on the intake?
To 98 fuel system help
