Driver seat erratic movement
Old Jul 29, 2005 | 01:04 AM
vetteship's Avatar
vetteship
Default Driver seat erratic movement
The driver seat movement is not continuous as I get ready to start the car. No codes are set (history or current). Seat starts to move, stops for a second or two, start moving forward again, then move to the half way position, stops and then move again. BTW the steering wheel is moving with one continuous motion while the seat is not. Any ideas why this is happening ? Thanks
Old Jul 29, 2005 | 08:58 AM
Bandit1's Avatar
Bandit1
Yep. Had the same problem about three years ago. There was a TSB on that issue. My tech replaced the seat memory module and the node in the BCM. Its been a while, so I don't have the specifics. If you have access to the TSB(s) history, its in there.
Old Jul 29, 2005 | 04:34 PM
vetteship's Avatar
vetteship
Thanks Bandit, I'll search for the TSB.
Old Jul 29, 2005 | 06:46 PM
UVETTYA's Avatar
UVETTYA
Me too.
To Driver seat erratic movement
