My dad and I are looking to install our halltech intake into our 04 coupe tonight...where can I get those directions?(i searched but had no luck)...wts...is their anything else I need to know prior to installing? Is it going to be tough?
dave
dave
Very easy mod- all you have to do is unhook the stocker intake and disconnect your MAF and pull the conacal sleeve off the Throttle Body. You will have to inset that sensor and reconnect it of course...but hook the MAF back up to the new system and reconnect it...very easy to do once you look at the old and the new next to each other. I did mine in 15 or 20 minutes.
Great mod by the way- the car loves that new introduction of air flow!
Just make sure everything is hooked up that you took off and you will have no problems...
