Rear end clunking??
The "turn corners" comment leads me to a suggestion. Check the differential for proper level. With car level it should just barely come out of the fill hole. If it's more the 1/4" lower than that, add additional and be sure to add a small amount of limited slip additive to the fluid too. Maybe 3/4 to 1 oz. If you're not sure about the proper ratio of limited slip additive to lube, and just want to drain the whole thing and start over, use the GM fluid and a full 4 oz bottle of GM limited slip additive. Or you can refill with Red Line 75W-90. It already has the the additive in it in the correct ratio. Not sure if Amsoil does, but maybe it already has it too.
Don't rule out the CV joints either. With the car up in the air, you may be able to track down the source of the noise by having someone hold one wheel while you rotate the other wheel back and forth. See if you can hear anything or feel excessive "slop". HTH
