Input / diagnosis of multiple error codes
P0171 Fuel Trim System Lean bank 1-B
P0174 Fuel Trim System Lean bank 2-B
P1431 Fuel Level Sensor 2 Circuit Performance -C
P1433 Fuel Level Sensor 2 High Voltage -C
P1626 Theft Deterrent System Fuel enable Circuit -C
U1096 Loss of Communications with IPC
U1064 Lose of Communications with DCM
B2282 Battery #1 Fault DCM-LEFT
B2284 Battery #2 Fault DCM-LEFT
U1064 Loss Of Communication with DCM (No SOH Message Received -RFA
B2283 Battery #1 Fault DCM-RIGHT
B2285 Battery #2 Fault DCM-RIGHT
Cleared codes and only the following reoccurred:
Any input on what might be going on? No drivability problems. Have Haltech intake and that's it for mods aside from CLB.
Thanks,
Scott
If I reset the codes, it will code again even at light cruising so it must be a pretty sizable one somewhere, if it is a leak.
Thanks,
Scott
Thanks,
Scott
Robert
www.gen3motorsports.com
I'm almost certain the service manual lists this as one of the possible causes of that fault.
Took off intake bridge and found a possible leak source at the plastic elbow connecting the filter to the MAF. Plastic had gotten soft (underhood temps, I suppose) and bowed in somewhat under the band clamp where the tightening bolt is housed. Took it off, gently molded the plastic back into it's original (round) shape, and re-connected band clamp using a bit less torque.
Interesting that a pre-MAF air leak could cause a lean condition-- I was originally focused on an upstream leak, for obvious reasons. Maybe the lack of diffuser screens in the C5 MAF caused it to get out of whack when a bit of turbulence (from leak) was introduced. Just speculation.
Thanks to all for the tips.
Scott
