Fixing broken grounding bolt
Old Jul 31, 2005 | 08:32 PM
gaww's Avatar
gaww
Default Fixing broken grounding bolt
Well, it seems that the issue was mainly corroded grounding points. However, I have a new problem: the bolt behind the driver side headlight that has one grounding wire along with another module of wires connected to it broke off while i was tightening the bolt. Now, how the hell do I fix the broken bolt? It's screwed into the actual chassis beam. Is there some type of super automotive conductive glue that I can use to glue back the two pieces? Please advise.
Old Jul 31, 2005 | 08:41 PM
muncie21's Avatar
muncie21
Had this issue myself. Try a self-tapping screw, to extend the ground wires to the nearest grounding point, which should be by the battery.
