Tire and rim question
Old Aug 1, 2005 | 05:53 PM
MrPickles's Avatar
0MrPickles
Former Vendor
Default Tire and rim question
Will a 335 fit on an 11.5 inch rim?
Old Aug 1, 2005 | 08:14 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
need to know the rim diameter, but here's the 17" and 18" tires.
335/35 YR17
106Y SL 220 AA A
2094 lbs.
51 psi
10/32"
33 lbs. 11-13"
12"
13.4"
NA
26"
787
mrr23's Avatar
mrr23
St. Jude Donor '15
335/30 ZR18
102Y SL 220 AA A
1874 lbs.
51 psi
10/32"
33 lbs. 12-13"
12"
13.3"
NA
26.1"
795
Old Aug 1, 2005 | 10:29 PM
shurite44's Avatar
shurite44
Yes it will, on an 18 anyway. Probably does not say so in the charts but it has been done. Hopefully some others can chime in that have done it. I know I have seen pics posted with this combo.
Old Aug 1, 2005 | 11:22 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
yes, it can be done. what will happen is curl the tread and sidewall some. 1/2" won't change it much. and most likely won't feel and negative affects from it. hell, years ago i put a N50-15 (315/50-15) on a 7" wide rim. now that took some effort.
To Tire and rim question
