shift points - a4
Old Aug 2, 2005 | 04:30 PM
C5Generl's Avatar
C5Generl
Default shift points - a4
where does a '00 c5 a4 make max power at? im about to reprogram my shift points on my predator. i had it set at 6100rpms across the board. i think these shift point hurt me in the 1/4. i going to set 1st at 5750, 2nd at 5800, 3rd at 6000 and 4th at 6000, i think i should be able to pick up some ET with the new shift points.......
your opinions please?
Old Aug 2, 2005 | 04:56 PM
STA-BLK's Avatar
STA-BLK
I think there too low.I picked up some et changing mine from stock to 6100 across the board.58xx seems very low
Old Aug 2, 2005 | 07:33 PM
Mike Mercury's Avatar
Mike Mercury
there are two fields for Predator shift points - RPM and MPH. On a mostly stock motor, set your individual gear shift RPM's to whatever your redline RPM is. Then set your global rev limiter 100 to 200 RPM above that.
To determine the MPH; place your A4 into "1" and take the car up to redline... note the MPH.
Do the same except with the tranny in "2". And if you're brave - with the tranny in "3". Set your shift MPH to 3 below those numbers.
Further tweaking may be necessary.
Old Aug 2, 2005 | 08:40 PM
leeman's Avatar
leeman
Default Shift Points
According to my G-Tech the LS1 develops maximum horsepower in the 5200 RPM range. The horsepower begins to drop after that. It makes no sense to me to run it up to 6000 or more RPM and risk hurting the engine when there is nothing to be gained according to my instrumentation. In fact, the stock factory shift points at 5500 to 5800 RPM starting out in third on my A4 seem to be optimal and have yielded my best times versus shifting at a higher RPM.
Old Aug 2, 2005 | 10:02 PM
Mike Mercury
sure there is. It's not all about where you shift... it's also about where you end up just after the shift.
You may be slightly past the power curve after 5200rpm - but the HP/TQ between 5200 and 6000 may still be more than the HP/TQ at the RPM it drops-to immediately after the shift.
That's why the 6 speed manuals are mathematically superior to the A4. Because with 4 gears to use before overdrive - they don't drop as far in RPM after a shift as us A4 guys do. All about keeping the engine in the power band.
If we had 5 or 6 speed automatics - then I'd agree - that would be a different story then.
Here's my actual time slip - with 6000rpm shifts -
2002 - A4 bone stock except for:
*3.42 rear axle upgrade
*Z06 airlid
*K&N drop-in OEM filter
*Predator DIY tune
still using factory tires and stock converter.
Old Aug 2, 2005 | 10:05 PM
yankeevetteconvert's Avatar
yankeevetteconvert
When you shift into the next gear your RPM drops to around 4000 RPM and your HP is much lower. You want to stay in gear as long as the HP is more than it is at 4000 RPM.On a stock engine this is in the 6000 RPM range.I have found on my vehicle that my best et's are obtained when I shift at 6100/6200 RPM.
Old Aug 2, 2005 | 10:12 PM
Mike Mercury
G-Tech meters are great for A-B or before/after comparisons... but the real world is on the street or at the track. There is where one learns that not all answers are found on the slide-ruler.
Old Aug 2, 2005 | 10:14 PM
TLKSCHP's Avatar
TLKSCHP
I get my best times at 6200, when the car was at 5900 I lost 2 tenths. My friend runs his stock motor at 6500 and always pulled me at the big end, I'm not that brave.
Old Aug 3, 2005 | 02:40 PM
Face's Avatar
Face
I agree with the others, 6100.
To shift points - a4
