Tire and rim size question.
Old Aug 2, 2005 | 08:22 PM
CORTVET's Avatar
CORTVET
From: Putting a 50¢ sticker of the U.S. Flag on a $50,000 import does not make one a patriot.
Default Tire and rim size question.
Stock are front 245/45/17(25.68 in.), rear 275/40/18(26.66 in.).
I am thinking for going with front(rim 19x10 in.) 275/30/19(25.50 in.), and rear(rim 19x11 in.) 305/30/19(26.20 in.)
My question is, if I go this route, will I need to reprogram my PCM for the tire and rim size change? Or is the over-all hight difference not enough to cause codes, and I can go with out any tuning?
Thanks,
AZC5
Old Aug 2, 2005 | 08:31 PM
pewterwest99's Avatar
pewterwest99
Thanks,
AZC5
I don't think it will cause any problems. I have seen vettes with up to 19''/20'' rim combo and I have never heard it cause any computer problems or require reprograming.
Old Aug 2, 2005 | 08:36 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
No problem, and no need to reprogram anything. Lots of people running those same sizes.
Bolt 'em on and go.
Old Aug 2, 2005 | 10:18 PM
5th Vette's Avatar
5th Vette
Check out www.1010tires.com/tiresizecalculator.asp You may be surprised what size tire will work and what won't work very well. Be careful not to oversize or you will have trouble braking. There is a warning pop-up window that alerts you when you have exceeded the 3% ratio.
Good Luck!
5th Vette
Old Aug 2, 2005 | 11:02 PM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
no problems here:
Rain
To Tire and rim size question.
