How often should...(cam/springs question)
Old Aug 3, 2005 | 01:57 AM
Forza1's Avatar
Forza1
Default How often should...(cam/springs question)
How often should the springs be changed in a car that has a G5x3 cam in it? Is this cam radical enough to require springs as a maintenance item?
Old Aug 3, 2005 | 11:09 AM
Z O SICK's Avatar
Z O SICK
If running the Comp 921 springs you can get anywhere from 10-20K. It all depends on how you drive the car. I have know guys to get 21K out of them running the X3/X4. I hope this helps.
