I just put long tube headers on my C5 & while I have it down, i'm replacing the plugs. Should I stay with the NGK TR-55's or go with something else? Thanks in advance for your help
Go with the AC Delco 41-985 Iridiums. They are now the stock plug for C5s. They are as good, or better, than anything else out there, and you won't have to change them out once a year as they're a long-life plug. I have never seen any documented, measureable proof that any plug, properly gapped, and properly heat ranged, from a reputable manufacturer, performed better than any other reputable manufacturer's plug, power-wise. You can usually buy them cheaper at an auto parts store than from a dealer.
Ed
Ed
What is the gap setting on these? Are they pre gapped?
THanks.
They come pregapped. If memory serves me right, it's .040. Take a look at the AC Delco website. I checked all of mine, in the store, at the time I bought them. They were right on.
Ed
Ed
yeah but the correct gap for the C5 is between .050 and .060 I do believe....
Ed
Been working on cars for 10+ years and that is true. The only ones I really stay away from are Autolite as they just paint their threads so they rust easier and stick in the head more.
Also do NOT use a ramp plug gapping tool on Iridiums as that will damage them and also a lot of Plat. tip ones as well. Use the right tool, but most Iridiums and even plats now seem to come pre-gapped.
