Fred Beans August C5 Specials!
Thank you for your interest in our August specials. We are offering all parts $499 and under @ 10% over dealer cost. All parts $500 or more are @ 5% over dealer cost. All engines are @ $100 over dealer cost. We discount all GM parts, not just C5, Fbody or GTO parts. If you are interested in anything other than what’s listed here please send me an email to gculley@fredbeans.com
||--Genuine GM C6 Shifter Kit--||
15232012 – C6 shifter
10354701 – C6 shift ****
11609670 - Bolt
Both parts 199.45 + 18.50 shipping
||--Genuine GM Engines--||
12498399 – 2002 + LS6 engine – 5130.13
12480030 – GM Performance Parts C5R block – 6350.00
89017654 – LS2 engine – 4899! 400 below dealer cost!
12568950 – LS2 bare block – 951.83 + 90.00 shipping
12572808 – 6.0 cast iron bare block – 651.59 + 90.00 shipping
||--Genuine GM Z06 Items--||
Z06 calipers – 337.46 + 15.50 shipping
Z06 front screens – 90.80+ 12.50 shipping
Z06 front brake ducts – 10295976, 10295977 – 16.29 each + 9.45 shipping
Z06 rear screens (scoops) – 10322761, 10322762 – 55.91 each + 12.50 shipping
Z06 rear brake ducts – 10425977, 10425976 – 16.01 each + 8.60 shipping
Z06 2004 shocks – 335.48 + 23.50 shipping
Z06 sway bar kit – 216.75 + 28.95 shipping
Z06 sway bar kit (insulators and bars only, no end links) – 152.39 + 26.50 shipping
Z06 front brake pads – 88952008 – 111.61
Z06 rear brake pads – 12530688 – 49.84 – shipping for front and rear is 14.50
Z06 rear differential assembly – 12572683 – 971.34 + 90.00 shipping
Z06 front suspension spring – 22178729 – 400.32 + 28.50 shipping
Z06 rear suspension spring – 22188038 – 400.32 + 28.50 shipping
||--Genuine GM HUD Setup--||
10279814 – HUD – 183.34
12198648 – Switch – 69.25
10425223 – Bezel – 17.95
Total setup is 270.54 + 18.50 shipping!
||--Genuine GM Tire Pressure Sensors/TPM--||
2001-2004 Sensors
25773946 - sensor – 57.38 each
15125473 - nuts – 2.56 each
Total setup is 228.88 + 15.50 shipping
97-2000 Sensors
10438853 - sensor – 88.42 each
10268439 - nut – 1.31 each (5 pack)
10268438 - washer – 1.31 each (5 pack)
Total setup is 350.10 + 15.50 shipping
||--Genuine GM Corvette Clutch Parts--||
89059282 - LS6 Slave Cylinder – 97.16
12564455 - LS6 Master Cylinder – 99.11
12570806 - LS6 Clutch Kit – 344.99
14061685 – LS1/LS6 Pilot Bearing – 9.16
Shipping for clutch is 45.00. The clutch + any other components is 55.00 shipping
||--Genuine GM LS2 Items--||
89017648 – LS2 intake manifold – 239.58 + flat fee of 5.00 shipping
12570790 – LS2 throttle body – 235.62
12572174 – LS2 fuel rails – 106.17
89017587 – LS2 injector o-rings – 20.09
||--Genuine GM LS6 Intake Manifold--
88894339 - Intake Manifold Only - 428.40!!
88894339 - Intake Manifold W/Coolant Pipes And Plugs - 455.28 shipped
||--Genuine GM UltraGuard UPF 44 Oil Filters--
25329389 - UPF 44 Oil Filter
Must order in cases of 6 @ 46.25 shipped!!
||--Genuine GM Cylinder Head Bolts And Gasket Kits--||
12498543 - 97-01 LS1 Engine Head Gaskets (2) – 31.96
12498544 - 02-04 LS1 & LS6 Engine Head Gaskets (2) – 22.77
12498545 - 97-12/03 LS1 & LS6 Engine Head Bolts – 15.48per head
17800568 – 01/04 – present LS1/LS6/LS2 Head Bolts – 14.95 per head
If you’re not sure which bolt kit to use please email us your VIN# and we’ll tell you!
||--Genuine GM Ceramic Brake Pads--||
88909667 – Front ceramic pad kit
88909668 – Rear ceramic pad kit
Both front and rear ceramic pad kits 104.74+ 14.50 shipping
||--Genuine GM Brake Rotors--||
OEM
10445856 – RF rotor
10445857 – LF rotor
10445858 – RR rotor
10445859 – LR rotor
Front and rear rotor sets 232.64 + 32.50 shipping
AC Delco Performance Drilled/Slotted
88926731 – RF rotor
88926732 – LF rotor
88926733 – RR rotor
88926734 – LR rotor
Front and rear rotor sets 178.36 + 38.50 shipping
||--Genuine GM T1 Engine/Suspension Items--||
T1 shocks – 583.48 + 28.50 shipping
T1 trans cooler – 877.68 + 28.50 shipping
T1 sway bar pkg with insulators and end links – 624.89 + 55.00 shipping
T1 complete suspension package – 2495.00 + 75.00 shipping
T1 suspension springs 696.17 each + 28.50 shipping each
||--Genuine GM Engine Parts--||
12564824 - '02 LS6 Cylinder Head (Assembly) – 729.75
12564825 - '02 LS6 Cylinder Head (Bare) – 674.38
12480110 - ASA Racing Cam - 375.87
12480033 - LS1 Hotcam Kit - 430.61
88958622 - LS6 CNC Ported Cylinder Head (Assembly) - 995.00each!!
||--Helms Service Manuals--||
'97'- '05 Corvette - 124.95 shipped!!
Please Call For Any Other Make/Model Vehicle!
||--Genuine GM LS1/LS6 Fuel Rail Covers--||
12559261 - '97-'98 LH Fuel Rail Cover (Black With Red "Corvette" Lettering)
12556455 - '97-'98 RH Fuel Rail Cover (Black With Red "Corvette" Lettering)
Both FRC’s 46.60 + 12.50 shipping
12561503 - '99-'02 LH Fuel Rail Cover (Black with Red "Corvette" Lettering)
12561502 - '99-'02 RH Fuel Rail Cover (Black with Red "Corvette" Lettering)
Both FRC’s 55.62 + 12.50 shipping
12564257 - '01-'02 LH Fuel Rail Cover (Red With Black "Corvette" Lettering)
12564258 - '01-'02 RH Fuel Rail Cover (Red With Black "Corvette" Lettering)
Both FRC’s 86.14 + 12.50 shipping
Fred Beans Pontiac Buick GMC Terms And Conditions Of All Sales:
We reserve the right to change the price of any part at any time and/or refuse to sell a part for any reason at any time. Price changes that can be made through the month are final and all sales before and after the price change are final. We will accept no returns after 30 days and all boxes or packages must be in the same condition as which they were received. If a package is received in anything other than perfect manner, please call and note upon receipt. Anything noted after the fact is the responsibility of the buyer. All returns are subject to a 20% restocking fee and/or a fee for unacceptable boxing or packaging. We reserve the right to change the terms and conditions of a sale at any time for any reason.
Also suggest a clutch bleeder extender so that you can flush your fluid on a regular basis.
Here is more info on it
