Cleaning O2 sensors??
Old Aug 6, 2005 | 07:18 PM
T.J.'s Avatar
T.J.
Default Cleaning O2 sensors??
Has anyone ever cleaned their O2 sensors with Carb cleaner? A mechanic told me Carb cleaner would be okay to use on O2 sensors and to wire brush them too.
Old Aug 6, 2005 | 08:46 PM
T_Vert's Avatar
T_Vert
i wouldnt do that. take a propane torch to them.
Dave
Old Aug 6, 2005 | 10:39 PM
servohead's Avatar
servohead
NOOOOO. Nobody should Ever "clean" an 02 sensor as far as I'm concerned. At least I can tell you that Volvo doesn't advise to do so, just to replace the sensor. From all the mechanics that I've known, across the board, cleaning an 02 sensor is not cool. Just replace it.
Whats the issue anyway? Slow response? Faulty signal? Fuel trim codes?
Old Aug 6, 2005 | 11:42 PM
T.J.'s Avatar
T.J.
No, just putting in my LT's and was wondering if they could be cleaned and due to the mechanic's advice. I've never had any codes or other concerns from the sensors. I'll just put some anti-seize on them and continue with the install.
To Cleaning O2 sensors??
