Passenger headlight stuck (no grinding)
Old Aug 7, 2005 | 11:25 AM
nericreations's Avatar
nericreations
Default Passenger headlight stuck (no grinding)
I've done searches on stuck headlights but all I seem to find is where the gear wore out on stock motors which caused grinding..
What happens on my car is I turn on the headlights, driver side comes up, but passenger side does not, if I open the hood and give the passenger side manual **** 1/4 turn, then turn the headlights off and back on, it works! no grinding...
The problem is I have to open the hood and turn the **** every night, what's strange is after I get the headlight up, it seems to work consistently after that, which means I can turn it off and on over and over and it works, except until the next day when I have to open the hood and repeat the process...
Any ideas from you corvette gurus? should I just replace the motor? I'm putting the car in the shop next week anyway...if so, anyone selling one?
Old Aug 7, 2005 | 12:17 PM
50 4Ever's Avatar
50 4Ever
Wil Cooksey #256
This might sound strange but it worked for me, both of my headlight doors would not close. Put the key into the drivers door and turn clockwise twice. After a friend did this to my Vette, I got in, turned the key on, turned the lights on then off. The doors closed. He said that someone told him that would "reset everything". I had to do this several more times on my 3-week cross country trip this summer. Now my left headlight motor is growling when I shut the lights off.
Hope it works for you
