Difference between A4 and a M6 differential?
Old Aug 7, 2005 | 11:33 AM
EDJ's Avatar
EDJ
Default Difference between A4 and a M6 differential?
Found a 3.73 differential out of a M6. Will it fit on a A4 with 2.73s?
Old Aug 7, 2005 | 11:54 AM
fdxpilot's Avatar
fdxpilot
Physically, it will go right in. You will need computer programming for shift points, etc.
Old Aug 7, 2005 | 11:57 AM
EDJ's Avatar
EDJ
Great! Thank you
Old Aug 7, 2005 | 11:59 AM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
You will need to re-use the plate on your current rear as the 6 speed does not use one. When you look at both rears you will see what i'm talking about. The plate is where the output shaft goes into the rear end.
Old Aug 7, 2005 | 12:07 PM
EDJ's Avatar
EDJ
Is that the seal that needs to be pried off? Also is a new TC needed or will the stock one work well. I don't race but thought about taking it to the local drag strip just to check out my times?
Old Aug 7, 2005 | 01:27 PM
Mike Mercury's Avatar
Mike Mercury
AMEN to that !!!
Don't forget to transfer over the seal plate. Here is a pic of a carrier with the seal plate missing:
stock one will work just fine. But if you ever plan on going with a higher stall TC... then you'll pay double the labor charges to do the gears seperate from the TC.
more info here:
http://mikemercury.home.att.net/342.htm
Old Aug 7, 2005 | 03:22 PM
EDJ's Avatar
EDJ
Thanks Mike, that's a great write up. I'm thinking of doing the work myself. Thanks for all the replies. Eric
To Difference between A4 and a M6 differential?
