Duh, I just remembered... the name of the company that makes the cooler was on my invoice - Setrab. A Google search for setrab transmission cooler will turn up tons of hits.
Yea thats the same one I have!!!! I wonder what its cooling capacity rating is compared to the big B&M cooler.
My cooler is rated at 18,000 GVW and measures 7.25"x11"x.75". I bought it from Oregon Performance and my transmission temps were in the 212-216 (As high as 223) range with 110 degree air temp and now temps have stayed under 187 degrees. Installed my cooler in series of the radiator and works great. It cost me around $54.00 shipped to my door.
Sounds like a value! Once installed, what's the proper method to fill ATF to proper level? My guess is the new cooler is at a greater height than the trans fill plug, on the side of the trans pan? Is there a separate fill plug in the cooler itself?
I believe you install cooler then run the car thru the gears. Then top off fluid at the tranny. Run thru gears and check again.
