Gas Door Stuck
Old Aug 10, 2005 | 12:04 PM
97vettec5's Avatar
97vettec5
Default Gas Door Stuck
I got to the gas station on empty of course, and hit the button and nothing. Almost ran outta gas trying to get home, but I did creep home. What the heck should I do? Should I try prying on the door, don't wanna scratch or break anything. Need help soon Thanks, Josh
RE: I can hear it clicking and it just won't click open
Old Aug 10, 2005 | 12:13 PM
Y2KC5NBM's Avatar
Y2KC5NBM
Cruise-In V Veteran
Senior Member
Default Emergency Release
Did you try pulling the emergency release wire inside your hatch? I had to use this once when I got my car back from the dealership. The technician had pulled the center console out to fix my turn signal problem (emergency flasher switch). When he put it back together he forgot to hook up the wire to the fuel release button.
Old Aug 10, 2005 | 12:15 PM
Pro Street's Avatar
Pro Street
In the trunk on the driverside there is a small silver cable(wire) you can pull to release the gas door.Give it a try!
Y2KC5NBM's Avatar
Y2KC5NBM
Cruise-In V Veteran
Senior Member
BTW - The emergency release wire is located on the drivers side by the gas door, but on the inside.
Old Aug 10, 2005 | 12:21 PM
97vettec5's Avatar
97vettec5
where exactly is the releaser cable, is it around the speaker somewhere. I just looked and can't find it. thanks again guys
Old Aug 10, 2005 | 12:29 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It looks like a stray thread, a thin silver wire. You may have to pull the carpet back a tad.
97vettec5's Avatar
97vettec5
haha thanks guys, I just found it, but my impatient dumbass thought it would be smart to just pry on it a little, and guess? snap, cracked a piece of the door. CONCLUSION TO ALL: be patient until you listen to what these guys have to say, before being a bull in a china shop, thanks again guys appreciate it
Old Aug 10, 2005 | 01:23 PM
AD2VET's Avatar
AD2VET
CI 2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '09-'10
Not laughing at you or what you did, just about the "be patient:" part. It's the hardest thing for me to do.
Old Aug 10, 2005 | 03:49 PM
lost's Avatar
lost
Wait till the hatch wont open at night.You will have to hire a very agile midget to get to that one!
To Gas Door Stuck
