Clutch/Tranny question
Old Aug 10, 2005 | 01:09 PM
J-PO's Avatar
J-PO
1st Gear
Default Clutch/Tranny question
First, a little background. I have 98 MN6. About two months ago while sitting a light with the clutch depressed and in gear the car moved forward an inch or so. It did the same thing a few weeks later. Then a week or so after that there was an awful rattle/grind when I depressed the cluth lever. I assumed that was the throwout brg. That too stopped. Now, I have no noise, but a nasty vibration at around 3-4000 rpm. I'm fairly sure it's the clutch package, as it's rpm related, not speed. My question is, how hard is it to change the clutch. I have done a dozen clutch/pressure plate replacements in other vehicles, but I think I once read here that removal consists of pretty much the entire rear end of the car. Is this true? Also, should I just go with a Z06 Clutch kit? The is car stock except for exhaust and intake changes.
