Predator??????'s
Old Aug 10, 2005 | 05:23 PM
JHALL8569's Avatar
JHALL8569
Default Predator??????'s
I have installed a predator on my 00 vert and it did seem to make a diffrence from stock applications for sure....but other than that i only have borla exhaust....it's a automatic and i would like for it to chirp 2nd when i gag it.....i know i can go into the predator and change the line pressure's and shift points and so on but what has worked good for others on the forum.....thanks
Old Aug 10, 2005 | 09:00 PM
CORTVET's Avatar
CORTVET
From: Putting a 50¢ sticker of the U.S. Flag on a $50,000 import does not make one a patriot.
I like +15 shift pressure and -15 shift time with the 3.15. Start there, the adjust to your liking.
Now that I run 3.73's, I like +5 shift pressure and -5 shift time.
What gears do you have?
AZC5
Old Aug 11, 2005 | 12:48 PM
INTHERED's Avatar
INTHERED
I had a predator on my 00 A4 last year and I raised the shift points to 6300 on the first two shifts with max pressure and minmum delay and it worked great. I was able to get into the 12s consistantly at the track with only a LS6 manifold, a Blackwing and a Corsa Pace
INTHERED
Old Aug 11, 2005 | 01:13 PM
Hokie's Avatar
Hokie
If you raised your shift points to 6300 wouldn't the car bounce off the rev limiter before shifting? If not what do you have your rev limit set to?
Old Aug 11, 2005 | 03:59 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
You don't need the predator to chrip the tires. Just get some traction thru 1st and floor it, At least thats what I do.
To Predator??????'s
