Loud noise when turning off headlights WTF?
Old Aug 11, 2005 | 12:03 AM
RJP51's Avatar
RJP51
Default Loud noise when turning off headlights WTF?
I get a loud noise coming from the LH headlight actuator when I turn off my headlights. Is there an adjustment for this or is the actuator bad ???
Thanks in advance!!!!
Rob
Old Aug 11, 2005 | 01:46 AM
Shark Racer's Avatar
Shark Racer
The gear probably needs to be changed. The stock plastic gear is known to be a weak point. There is a brass gear available aftermarket.
Old Aug 11, 2005 | 07:59 AM
TomT's Avatar
TomT
Got my metal gears from Rodney Dickman's. Fast delivery and very helpful.
Works fine ever since.
Takes some time to install but instructions are good.
I went slowly and life is A/OK in headlightland.
Old Aug 11, 2005 | 09:25 AM
BMG50's Avatar
BMG50
very same thing happened on my 99...did the above also...fixed!!!
Old Aug 11, 2005 | 10:24 AM
RJP51's Avatar
RJP51
Anyone have a phone number or website to purchase these?
Thanks,
Rob
Old Aug 11, 2005 | 06:19 PM
maacoman's Avatar
maacoman
Heres the website. Same thing happened to me..
John
http://www.rodneydickman.com/retail.html
Old Aug 11, 2005 | 10:53 PM
RJP51's Avatar
RJP51
John
maacoman,
Thanks for the website, however the part isn't listed. How do you contact them?
Rob
Old Aug 11, 2005 | 11:21 PM
RJP51's Avatar
RJP51
John
maacoman,
Rob
Old Aug 12, 2005 | 08:28 AM
TomT's Avatar
TomT
A. Click on logo in website
B. Write down phone number
Old Aug 23, 2005 | 12:01 PM
RDVT4ME's Avatar
RDVT4ME
Same thing just happened to me. How much do these gears cost? I assume not much. Also, how tough is it to install?
Old Aug 23, 2005 | 12:08 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I have pics and a DIY how to..if you email me
Old Aug 23, 2005 | 01:34 PM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
Yup, same thing here and the brass gear is the way to go.
Go to http://www.rodneydickman.com/retail.html, click on the "Electrical" tab at the top, scroll down to "Headlight -- Other Vehicle and click on the " 97+ C5 Corvette Brass Headlight Gears" link. Scroll down, select quantity and then click "Add to cart" link.
Old Aug 23, 2005 | 02:28 PM
BMG50's Avatar
BMG50
I THINK MINE WAS ABOUT 40-45.00 SHIPPED.... EASY INSTALL
Old Aug 23, 2005 | 11:40 PM
108C6's Avatar
108C6
gm has a tsb for this problem where you install washers and new rubber stops has fixed many for me i work at a dealer as a tech
Old Aug 24, 2005 | 01:19 AM
hightest's Avatar
hightest
You should try spraying the headlight hinges with silicone lube first.
Stopped the horrid noise on mine, and haven't had a headlight squeak or peep since.
Old Aug 30, 2005 | 01:11 PM
ITSBILL's Avatar
ITSBILL
Default Confirm?? Headlight clicking after going completely closed
Team,
Not sure if I have the same issue or if it is the headlight moter gear.
When I turn on the lights, they pop up with no problem or noise. When I turn off the lights, they close with no problem, but after they are completely closed, the lift "autator" keeps spinning and make a loud clicking noise for about 15 seconds. Any suggestions?
Thanks,
ItsBill
99'vette
Old Sep 5, 2013 | 04:27 PM
FredCDobbs's Avatar
FredCDobbs
Has anyone else fixed their noise problem with lube and not had to change out the gear?
To Loud noise when turning off headlights WTF?
Old Sep 6, 2013 | 08:40 AM
eldudereno's Avatar
eldudereno
The previous post was made 8 years ago Fred.
If you don't want the expense of replacing the gears, try unbolting the linkage arm from the motor shaft, rotate the shaft by 180 degrees, then re-attach the arm. You'll then be using the teeth on the opposite side of the gear which will mostly have been previously unused.
Old Sep 6, 2013 | 12:20 PM
Blueleader's Avatar
Blueleader
Default Needing suggestions for the L headlight spinning
Originally Posted by ITSBILL
Team,
Thanks,
ItsBill
99'vette
This is what mine is doing- whats the fix? It wouldnt open at first. I massaged the wiring and the WD40 on all moving parts. It has been stored for 8 years. So I expected some gremlins! Now opens but closes with a spinning for 15 secs....
Any suggestions??
Old Sep 7, 2013 | 12:27 AM
CactusCat's Avatar
CactusCat
Any suggestions??
Yep, you've got the bad gear problem. The nylon gears go bad and the teeth get broken. So you need a brass gear replacement. Here's the link:
http://my.execpc.com/~rodney1/vettegears/index.htm Not a hard job, takes about 45 min or so per side. Instructions on site as well.
