2005 LS2 Crate Engine
Old Aug 11, 2005 | 02:19 PM
stromadd's Avatar
stromadd
Default 2005 LS2 Crate Engine
Will this engine work in a 2004 Chevy SSR and if so, what would you need in addition to it to get it to work with the SSR? Also..anyone know where I can get the part numbers for the pulleys, serpentine belts, power steering pump, a/c pump, starter, alternator and engine covers that go with the LS2 engine? THanks.
Old Aug 11, 2005 | 02:26 PM
stromadd's Avatar
stromadd
...also, the ecm and wiring harness part numbers would be helpful
Old Aug 11, 2005 | 03:58 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Inb4tm
Old Aug 11, 2005 | 04:59 PM
stromadd's Avatar
stromadd
huh?
Old Aug 11, 2005 | 09:45 PM
junkbondguy's Avatar
junkbondguy
6th Gear
why spend 8-10 grand on the new engine... go get new heads a cam and intake cost you about 4 grand and you will pick up 60-90 hp
Old Aug 12, 2005 | 12:51 AM
stromadd's Avatar
stromadd
I can get the engine for 5,625.
Old Aug 12, 2005 | 12:47 PM
stromadd's Avatar
stromadd
anyone else have some ideas?
Old Aug 12, 2005 | 01:05 PM
shurite44's Avatar
shurite44
Originally Posted by screw991le
Inb4tm
He is posting In Before the Move, the reason this is the C5 tech. So your truck is not a C5 and the engine comes from a C6, most likely the moderator will move this to the appropriate forum.
Old Aug 12, 2005 | 01:16 PM
stromadd's Avatar
stromadd
oh, ok...thanks
To 2005 LS2 Crate Engine
