AFR's G5-X2 WHAT HAPPEN?
Old Aug 12, 2005 | 10:47 PM
DVS 99's Avatar
DVS 99
Default AFR's G5-X2 WHAT HAPPEN?
Last month did AFR 205's, G5-X2 on a 112. The results were very disappointing! Did all the work myself including the fly-cutting, and HPE did the final tune. Guys the car smells very rich at idle and will not run below 1800 RPM, car surges and buck in all gears. Is this characteristic of this camshaft or is it the TUNE? Car only made 410rwhp through stock cats, MAF sensor, and throttle body. What happen, I was expecting more? By the way it is a MN6.
Old Aug 12, 2005 | 10:58 PM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
I have the G5X3 on 112 and I get some surging if I lug it around but its very drivable without any major issues and since its bigger than the X2 I would think you might have a tunning issue.
Since your running cats I wouldn't think you shouldn't smell much if anything, I'm catless and mine only stinks if I'm sitting still a long time like in a drivethru.
Phil97SVT's Avatar
Phil97SVT
Get that thing tuned.
Phil
Old Aug 12, 2005 | 11:04 PM
SideStep's Avatar
SideStep
You went to the dyno and did not get it tuned???
Old Aug 13, 2005 | 06:02 AM
msghuff's Avatar
msghuff
Sounds like the tune needs work... but dont get wrapped up in numbers how does it run?
Old Aug 13, 2005 | 07:55 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Get the tune. EnglandGreen did his own work and the car was very undriveable. He got the tune and the car is great to drive now and he picked up another 27RWHP.
Old Aug 13, 2005 | 12:16 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Phil
Old Aug 13, 2005 | 01:33 PM
FULTILT's Avatar
FULTILT
Why would HPE give the car back to you like that without a reason? There has got to be more to the story.
Old Aug 13, 2005 | 03:37 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In V Veteran
It will run a bit crappy on the low side with the stock tune. Have the car tuned and you will see that is a very streetable cam. I have the G5X3 in my own car ind its very docile
Old Aug 13, 2005 | 08:20 PM
DVS 99's Avatar
DVS 99
Must be because I didn't use there cam. HPE said "This is a characteristic of LG X2 camshaft, LIVE WITH IT!"
Old Aug 13, 2005 | 08:24 PM
DVS 99's Avatar
DVS 99
HPE DID A TUNE!
Old Aug 14, 2005 | 08:39 AM
SteveDR425's Avatar
SteveDR425
I am sorry but HPE did a horrible tune on your car if you have an idle of 1800 RPM . Second them saying that this is the characteristic of an X2 cam is total BS . I have an X2 cam with AFR heads in my car and I am very street able. I idle at 850 rpm and the car runs great. I would take it to a tuner that knows how to tune a cam as big as a X2, because HPE obviously does not know how.
Good Luck..
Old Aug 14, 2005 | 11:09 AM
DVS 99's Avatar
DVS 99
U must of read it wrong. The car idles at 900 rpm but surges below 1800 rpm.
Old Aug 14, 2005 | 07:38 PM
99blackFRC's Avatar
99blackFRC
sounds like they don't know how to tune a car honestly..
Old Aug 14, 2005 | 09:04 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
I have the G5X2-112, idles @ 950 with no real problems. I was going to buy the AFR 205's and talked to Matthew & Bobby at LG both said flycutting wasn't necessary with 66cc or 64cc heads...what cc did you buy? A good tune woke mine up
Old Aug 15, 2005 | 08:13 PM
DVS 99's Avatar
DVS 99
I have a 62cc head.
Old Aug 15, 2005 | 08:27 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
That is your tune!!!
234/240 598/608 114LSA in a A4 with stock TC and TALL 2.73 gears.
Before the tune - It was a nightmare. Bucked, surged, no hot start, stalled, convulsions..... a long list of
The tune makes my car drive like stock (almost). Zero bucking, no surging, no convulsions, no run on, it hot starts, idles in gear at a light with the A/C on..
It's all in the tune. Slowhawk of Dez Racing in Mass. did an awesome tuning job on my car and I highly recommend him.
EG
To AFR's G5-X2 WHAT HAPPEN?
Old Aug 15, 2005 | 08:29 PM
0EG@EnglandGreen
Supporting Tuner
I absolutely agree with Chris.
Old Aug 15, 2005 | 08:36 PM
LG Motorsports's Avatar
LG Motorsports
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
You said "Stock Cats"? so what headers do you have? Take it on a drive up here to Dallas and we will fix you right up. A G5X-2, installed correctly is a dream.
Seriously, give me a call. If you are in Houston, we are in Dallas, and we can help.
Lou Gigliotti LGM
Old Aug 15, 2005 | 08:49 PM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Lou Gigliotti LGM
That is an offer you can't refuse...
