Tire plug question
Old Aug 13, 2005 | 11:37 PM
Black ZR1's Avatar
Black ZR1
Default Tire plug question
Not sure where to post this. But with all the geniuses that own C5s, I figured this would be as good as any place.
About 15 of us are doing a Sequoia run tomorrow morning, Sunday. This evening, I got a road hazard slit in my back tire. Slit is on bottom, not on side walls. Run Flats. It's my wife's 2001 Vert. No one around to fix or replace.
It took two plugs to stop the leak. Is this safe? We'll be going about 200 miles tomorrow. Of course, I'm going to replace the tire when I get back.
Thanks.
Old Aug 13, 2005 | 11:55 PM
bglmn's Avatar
bglmn
Thanks.
...just take a plug kit with you, as well as a compressor.
Old Aug 14, 2005 | 12:05 AM
LS9's Avatar
LS9
I know of people who have use double plugs just to get home . I personally wouldn't trust it for any length of time
Old Aug 14, 2005 | 12:19 PM
jimcork1's Avatar
jimcork1
Thanks.
Two plugs have never worked for me,, they almost always give a problem. For a temp fix at low speed to get home,, ok,, but otherwise,, I would replace the tire. 99 Nassau blue
Old Aug 14, 2005 | 12:49 PM
shurite44's Avatar
shurite44
If it is holding air and you are doing normal driving I would also just take along a cell phone and a plug kit, compressor. It is a runflat so if you have to you can drive on it. No high speeds.
Old Aug 15, 2005 | 01:54 AM
Black ZR1's Avatar
Black ZR1
Thanks for the advice. Tire went empty overnight, so we took my ZR1 to the Sequoias.
Unfortunately, on the way back, on Hwy 99, in the middle of nowhere, my ZR1 got a blow out.
Man, sometimes, thing really suck.
Old Aug 15, 2005 | 06:36 AM
ebubman's Avatar
ebubman
geezzz, talk about bad tire luck . hope your tire luck takes an upswing soon! bub
Old Aug 15, 2005 | 07:43 AM
cowpunk's Avatar
cowpunk
Take your EMT to Goodyear Dealer. See if tire can be patched. Goodyear has a EMT training program that includes repair. Plugs do not keep air from entering body plies and causing separations. Best of luck.
Regards,
Jay Lee
Support your local Tire Dealer
To Tire plug question
