Hidden Settings
Old Aug 14, 2005 | 03:19 AM
tem00's Avatar
tem00
Default Hidden Settings
Is there any hidden setting or button sequences in the C5
I know the reset for trouble codes, view trouble codes, and oil life.
Just curious
Old Aug 14, 2005 | 08:20 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
If you hold down the Options button and press Fuel 3 times real fast then Reset Trip and Gages in quick sequence the car gains 100 rwhp
Old Aug 14, 2005 | 11:54 AM
50 4Ever's Avatar
50 4Ever
Wil Cooksey #256
Old Aug 14, 2005 | 08:05 PM
tem00's Avatar
tem00
A comedian, I like that but i thout you had to push the fuel buton 4 times, and you only gain 50 rwh.
Old Aug 15, 2005 | 08:15 AM
pewter99's Avatar
pewter99
see you didn't read the blank pages in the manual under the special light
Old Aug 15, 2005 | 08:27 AM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Maybe he didn't get the "special manual" because he didn't wear the decoder ring and give the secret handshake when he picked up the car.
Old Aug 15, 2005 | 08:41 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
But under NO circumstances should you push it 5 times.
Not exactly hidden, but you can reset codes while driving (assuming you're coordinated.)
Old Aug 15, 2005 | 10:23 AM
kasper-pA-'s Avatar
kasper-pA-
St. Jude Donor '05, '14, '15
hold down your active handling button while stopped, or parking brake up, and it will enable competitive driving mode
Old Aug 15, 2005 | 10:56 AM
MawneeC5's Avatar
MawneeC5
up, down, up down, left,right, left, right, A, B, A, B, select, start. Good for +100
Old Aug 15, 2005 | 11:01 AM
kasper-pA-'s Avatar
kasper-pA-
LOL
thought it was for 30? heheh
Old Aug 15, 2005 | 11:51 AM
pewterwest99's Avatar
pewterwest99
No, that's for unlimited ammo for your heat-seekers
Old Aug 15, 2005 | 11:52 AM
Mike Mercury's Avatar
Mike Mercury
Old Aug 15, 2005 | 12:51 PM
Shylor's Avatar
Shylor
I can do my 2003's while driving also. But this isn't a hidden setting, it's clearly in the owners manual.
Old Aug 15, 2005 | 02:46 PM
EatRice's Avatar
EatRice
Do mean the special light they use on CSI to see semen? I tried that with my manual and all I get is funny looking spots on my back....what is with that? I think the light is broken.
Old Aug 15, 2005 | 02:48 PM
Shylor's Avatar
Shylor
It's called a Black Light.
Old Aug 15, 2005 | 07:53 PM
The Dingo's Avatar
The Dingo
Old Aug 15, 2005 | 11:00 PM
ditty22's Avatar
ditty22
hahahah thats good ****.
To Hidden Settings
Old Aug 16, 2005 | 06:46 AM
pewter99's Avatar
pewter99
no...lemme correct you....it's an "alternative light source" several different wave lengths of light viewed thru glasses that filter out particular wavelengths depending on what you are trying to see.
anyway...anyone know how this project is going?
Old Aug 16, 2005 | 09:27 AM
yellowvette837's Avatar
yellowvette837
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
Well EatRice's experiment did not go well.
He thinks his "alternative light source" is broke
Old Aug 16, 2005 | 11:54 AM
yellowvette837
He thinks his "alternative light source" is broke I always thought the evidence told the truth.
