Cam specs
Old Aug 14, 2005 | 03:59 AM
2004SpiralGrey's Avatar
2004SpiralGrey
Default Cam specs
What is the specs of a stock cam on a 2004 LS1 coupe?
Old Aug 14, 2005 | 04:20 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I would imagine they are the same as these......I couldn't find anything else
The specs for a 1997-2000 C5 LS1 cam are as follows:
- Intake / Exhaust Duration @ .050" Lift: 202 / 210 Degrees
- Intake / Exhaust Lift: .472" / .479"
- Lobe Separation Angle: 117 Degrees
Old Aug 14, 2005 | 07:34 AM
Iron Maiden Fan's Avatar
Iron Maiden Fan
Actually, the cams on the pre-'01 engines were a little stronger. When the pup cats were done away with in 2001 the cam was made smaller. I think this link will shed some light.
http://www.smokemup.com/tech/ls1.php
Old Aug 14, 2005 | 10:35 AM
C5XTASY's Avatar
C5XTASY
1997-1999 LS1 / Y-car .472/.479 ** duration 199-207 ** LSA 117
2000 LS1 / Y-car .500/.500 ** duration 198-209 ** LSA 115.5
2001-2004 LS1 / Y-car ** .467/.479 ** duration 196-207 ** LSA 116
2001 LS6 / Y-car ** .525/.525 ** duration 204-211 ** LSA 116
2002-2004 / LS6 Y-car ** .551/.555 ** duration 204-217 ** LSA 117.5
For the LS1, the 2000 cam was the strongest of any year.
Ed
Old Aug 14, 2005 | 06:24 PM
2004SpiralGrey
thanks
To Cam specs
