373 gears
Aug 14, 2005 | 02:28 PM
373 gears
Has anyone put in 373 ring & Pinion Gear Set without a new Differential? How is it?
Aug 14, 2005 | 02:47 PM
It's a perfect street gear. And it doesn't eat up gas. Shold have been an option.
Aug 14, 2005 | 03:22 PM
Yea i would liek to know too. I am going from 3:42 to 3:73 how much of a differance will i see?
what is your current ratio ?
Aug 14, 2005 | 03:43 PM
I have the 315 now does putting in just the gear make any noise or wine? I had a friend that had just the gears put in and they wined.
Aug 14, 2005 | 03:47 PM
Cruise-In V Veteran
St. Jude Donor '04
Quote:
If they whine then they weren't set up properly, I had 3.73 gears in my car for a while and this is by far the best mod that everyone should try.
Aug 14, 2005 | 05:19 PM
I have 4.10's and they don't make any noise. It's all how they're set up and broken in.
Aug 14, 2005 | 06:16 PM
Quote:
I have mine in for over three years and they are great. Do it you will love them.
Aug 14, 2005 | 06:36 PM
Quote:
How do you break them in?
Aug 14, 2005 | 06:38 PM
Thanks for the info.
I could not see getting a new differential for 1400 plus 1000 core when the gear set is 399.00 from WCC
Aug 14, 2005 | 06:40 PM
St. Jude Donor '05
Quote:
me too, thinkin about going to 3:73 from 3:42 gas mileage,is it worth it A4 car, SS3600 t/c. thanks
Aug 14, 2005 | 06:56 PM
if 4.10's can be setup to where there's no whine - then 3.73 should be a sure thing (but it's dependant upon who does the work though).
Aug 15, 2005 | 12:43 PM
Who are you going to have do the install? I'd call ECS, they may not be too far of a drive for you. It'll cost around $1200 installed.
As for break in proceedure, it's simple. No WOT, burnouts, etc.. or staying at the same speed for too long for 400 miles. Then have the fluid changed.
Aug 15, 2005 | 08:24 PM
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I just had 3.42's put in w/ a 2600 stall TC back in July only about 600mi on them,I'm already thinking about going to 3.73's.Don't get me wrong.The 3.42's & TC are awsome.BUT its never fast enough.Why is that?
