Thermostat, cooling question
I replaced the throttle body and thermostat in my 2002 z06 yesterday and I have some cooling issues. I used a 180* Hypertech Thermostat (technically for a ls1 camaro but was told it works and it fit perfectly). I filled with coolant and water wetter but here is the issue. Today was about 80* out and at idle the coolant temp goes all the way up to 228* but not higher. When I turn on the fan/AC the temperature goes WAY down but it won't get cool like that without me turning the fan on manually.
My question is could there be something wrong with the thermostat or is this normal? I will eventually get the fans programmed to come on earlier but this seems to be too hot given the ambient temperature. Any thoughts?
In hot weather, the cold end of the spectrum isn't an issue.
Once your coolant temp reaches 180, your new Tstat opens.
From there, it is up to the radiator and fans to limit how hot it will run. Since you've done nothing to change those, your max temp has not changed.
Don't you think a top out of 228 is a little extreme?
Thanks in advance!
I wouldn't worry unless it exceeds 235 (the high speed fan turn-on point).. If it's running hotter than that, you likely have a clogged radiator issue.
