i have code 58-sdm u1040 loss of communication with tcs
10-pcs p1571 asr desired torque
28 tcs no communition
i have tried to clear these codes the keep coming up my service vehile soon message in the dic pops up and my abs light is on and my traction control light is on what do i need to do to repair thiese problems thank you
I believe (correct me if I'm wrong) but SDM stands for sensing & diagnostic module, if you have a loss of communication with the traction control system then you may have a bad ebtcm (electronic brak & traction control module) or a bad ground, do a search for a forum member by the name of Bill Curlee, he has a great thread on how to check your ground points.
If you plan on doing your own work you may want to invest in these Service manuals but if you don't plan on working on your car you may just want to find a reputable mechanic to troubleshoot for you.
