Problem w/Easy Entry/Memory Feature
Old Aug 17, 2005 | 04:55 PM
chaase's Avatar
chaase
St. Jude Donor '12
Default Problem w/Easy Entry/Memory Feature
Has anyone had the following problem...When I get into the car using my remote, I get in, close the door and put the key in the ignition. The steering wheel moves into the correct position, but the seat doesn't go forward as far as it should. (i.e. If I hit memory 1 a couple of the times the seat goes forward a couple of times and then stops).
Any ideas, thoughts, had this happen to you?
Thanks,
Chris
Old Aug 17, 2005 | 11:15 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
I had a similar problem. My seat would stop and if I tried to move it with the seat switch it would move for 1 second then stop. I would repeat this 4 or 5 times before It would start moving properly again. I recently had the battery disconected while I was working on the car. When I reconected it the seat issue was gone. It's worth a try.
Old Aug 18, 2005 | 10:01 AM
chaase's Avatar
chaase
St. Jude Donor '12
Maybe I will give it a try...Damn Gremlins
To Problem w/Easy Entry/Memory Feature
