Why does my car under perform?
Old Aug 17, 2005 | 08:25 PM
HIGH_INTREST's Avatar
HIGH_INTREST
St. Jude Donor '08
Default Why does my car under perform?
I have a 99 FRC and no matter what mod I do it always under performs.Just a few examples:
(old setup)
Stage II H/C w/MTI X-1 Cam
TPIS 1 3/4 LT w/Hi-flow cats
3.90 gears w/harden output shafts
Corsa
total HP:390RWHP
added 150 TNT kit 530Rwhp
(new setup)
408 iron block 10.8-1 CR
Lunati Crank
Lunadi Rods
Wiesco Pistons
MTI S-1 Cam
90/90 Fast intake
1 7/8 Kooks
Hi-flow cats
Corsa
480RWHP
All the work has been done by MTI in Houston.
What could be causing the car to not put out the HP it should?
Old Aug 17, 2005 | 08:46 PM
sams96's Avatar
sams96
Does MTI use a mustang dyno? Also in the heat that we are seeing right now I wouldn't expect big numbers. On your old setup the cam was to small. On your new setup I'd run more compression and a bigger cam. The S1 cam that MTI has is big for a 346 but not a 408. I'm running a TSP 233/239 600/603 on a 112 +2 in my A4. Don't have dyno numbers but 11.5 @120 in the heat. Worst case is sell the MTI heads and buy some AFR 225 . Then you'll make some big power.
Old Aug 17, 2005 | 09:41 PM
HIGH_INTREST
St. Jude Donor '08
No they don't use a Mustang Dyno.
They set the motor up for nitrous.I have since decided to go with a blower and nitrous.They are installing a D-1SC as we speak.
To Why does my car under perform?
