Locked Steering Wheel
Old Aug 18, 2005 | 07:31 PM
keysboy182's Avatar
keysboy182
Default Locked Steering Wheel
When I went to start my car, the steering wheel wouldn't unlock. It started, but the display said, "Service Steering Lock." I couldn't turn the wheel. Has anyone ever heard of this and how expensive is it?!?!?! Thanks for the help!
Old Aug 18, 2005 | 07:33 PM
Dustie's Avatar
Dustie
Try reading the sticky at the top of this page for lots of good info on this common problem.
Old Aug 18, 2005 | 07:59 PM
jman1's Avatar
jman1
......... sorry.... you've got the coulmn lock
Old Aug 18, 2005 | 08:18 PM
Get a Vet's Avatar
Get a Vet
keysboy,
You can try this too. Put the key in the ignition and turn it on, but don't start. Turn the wheel a little to the right to where the wheel "locks", then give the wheel a quick yank to the right. It should "un-pop". I had to do this several times until I could get a bypass relay kit.
The relay kit keeps the column lock from engaging and
there might be a Tech note at the forum on how to install it vs. going to the dealer. It's pretty easy and my kit cost $100 (for a relay and a connector...go figure!).
Hope this helps.
Old Aug 19, 2005 | 01:43 PM
keysboy182's Avatar
keysboy182
Default Thanks
thanks a lot. however, i already had it towed to the dealer yesterday! I think that b/c it was a recall they are going to fix it free of charge. (fingers are crossed!) Either pay my tuition or have my vette fixed....thats a no brainer!!!
Old Aug 19, 2005 | 01:55 PM
rws.1's Avatar
rws.1
Ahhh most people don't take it to the dealer cause they DO NOT FIX it..
They just reflash the PCM.
If it happens a second time, they may remove the locking plate( if it is an auto) IF it is a mnual there is no dealer fix. You need to install a CLB
(column lock bypass) form either Thunderracing.com or Corvettesofhouston.com
Do educate yourself by reading the sticky. The prefered member fix costs $49....
Old Aug 19, 2005 | 02:00 PM
rws.1's Avatar
rws.1
here is another current thread....your issue is probably the most posted issue on the C5 forum...
http://forums.corvetteforum.com/show...7&forum_id=103
To Locked Steering Wheel
