Et Performance
Old Aug 18, 2005 | 09:15 PM
blktie8's Avatar
blktie8
Default Et Performance
Have you seen the new heads
Flow numbers to follow .
http://forums.corvetteforum.com/show...120&forum_id=1
Old Aug 19, 2005 | 10:20 AM
blktie8's Avatar
blktie8
ttt
Old Aug 19, 2005 | 06:21 PM
Ed Curtis's Avatar
Ed Curtis
Here are some flow numbers per Craig at ETP
215cc 11° Valve Angle
Intake Exhaust
.100" 74 57
.200" 152 106
.300" 219 150
.400" 266 190
.500" 301 204
.550" 312 208
.600" 320 211
.650" 323 214
*Flowed on 3.900" bore w/o pipe
225cc 11° Valve Angle
Intake Exhaust
.100" 71 57
.200" 153 114
.300" 208 163
.400" 265 204
.500" 308 222
.550" 320 228
.600" 328 231
.650" 332 234
.700" 320 236
*Flowed on 4.000" Bore w/o pipe
240cc 11° Valve Angle
Intake
.100" 73
.200" 152
.300" 210
.400" 266
.500" 312
.550" 327
.600" 338
.650" 346
I have flow numbers now, I want to verfiy to make sure they are correct.
265cc 11° Valve Angle
Intake Exhaust
.100" 73 55
.200" 155 113
.300" 212 159
.400" 271 213
.500" 323 229
.550" 338 234
.600" 352 236
.650" 365 239
.700" 376 242
.750" 380 243
*Flowed on 4.000" bore w/o pipe
Ed
Old Aug 19, 2005 | 10:02 PM
Scubanme's Avatar
Scubanme
How much are the heads?
Old Aug 19, 2005 | 10:13 PM
blktie8's Avatar
blktie8
Default Thanks Ed
I haven't been able to post,I guess my excel spread sheet is too old .
Anybody interested in pricing can contact Ed Curtis.
I can help if you need immediate attention as I live near the Et Performance Production facility.
John Sr.
Old Aug 19, 2005 | 10:23 PM
427CPE's Avatar
427CPE
Intake Exhaust
.100" 74 57
.200" 152 106
.300" 219 150
.400" 266 190
.500" 301 204
.550" 312 208
.600" 320 211
.650" 323 214
Intake Exhaust
.100" 71 57
.200" 153 114
.300" 208 163
.400" 265 204
.500" 308 222
.550" 320 228
.600" 328 231
.650" 332 234
.700" 320 236
Intake
.100" 73
.200" 152
.300" 210
.400" 266
.500" 312
.550" 327
.600" 338
.650" 346
Intake Exhaust
.100" 73 55
.200" 155 113
.300" 212 159
.400" 271 213
.500" 323 229
.550" 338 234
.600" 352 236
.650" 365 239
.700" 376 242
.750" 380 243
Ed
Looks like a great set of heads. How does (set 1 comparabe?) compare to stock LS6 heads w/respect to airflow? What hp gain on stock LS6?
What does the acronym ETP stand for? Data?
Old Aug 19, 2005 | 10:34 PM
Ed Curtis's Avatar
Ed Curtis
Well... I can answer some Tech questions but because I'm a outsider (non-sponsor) I can't help with price checks...
As for the LS6 vs 215 heads... I'd venture about 40-45 RWHP with a good tuner. Even more with a top shelf guy (A&A)....
ETP = ET Performance
Ed
Old Aug 19, 2005 | 11:56 PM
427CPE's Avatar
427CPE
my z06 is completely stock. so if I add these heads, 40rwhp minimum, no other changes?
What do you think of a cam setup for the 215s with a lsa of around 117, agressive ramps and moderate duration @ 0.050. Something like
214/224/ commensurate w/air flow lift of heads(600??), 117 or so lsa like stock. i could be wrong, but it appears these ls6 engines don't need overlap on the cam with a stock exhaust.
Old Aug 21, 2005 | 01:04 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
ETP produces some of the most respected CNC'd heads in the industry and their new cylinder heads are setting benchmark flow numbers.
We will have a set or two in the next few weeks (depends on ETP's back order status) and publish our independent dyno results.
Charlie
Old Aug 21, 2005 | 01:55 AM
427CPE's Avatar
427CPE
I could probably get 370rwhp with stock heads and tuning. Have seen 364 already. Thats only 28rwhp off your FULLY MODDED ETP HEADED, LONG TUBED, COMP CAMS (ED CURTIS) engine. What am I missing?
Old Aug 21, 2005 | 01:25 PM
427CPE's Avatar
427CPE
Thats great, except someone is blabbing about 40rwhp gains++. You gonna back those claims or is this BS???
Old Aug 21, 2005 | 02:23 PM
Ed Curtis's Avatar
Ed Curtis
Whoa dude... WTF is it with the attitude?
You asked, and I gave you "my opinion" based on the delta between the cylinder heads and potential HP increases when the combination is maximized. If you don't agree fine but cripe, lighten up!
Don't bother looking for an answer to your cam ideas either. I'm done giving out any more info for free. Try Google.
Ed
Old Aug 21, 2005 | 03:32 PM
0C_Williams@RPM
Former Vendor
We will post our results. I don't no about blabbing but I do know that the potential exists and my advice is to wait for the dyno and track times before arguing otherwise.
Old Aug 21, 2005 | 03:33 PM
Corvette4ever's Avatar
Corvette4ever
So which intake manifold should we use with those heads?
Old Aug 21, 2005 | 06:02 PM
0C_Williams@RPM
Former Vendor
FAST 90 with LS2 TB....
Charlie
Old Aug 21, 2005 | 06:47 PM
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
If those numbers are real out of the box and untouched. That's really good especiall on a 4.000" bore.
Like Charlie said. Let's see the dyno results.
I say, let's see the track numbers to follow.
Amazing stuff coming to market.
Old Aug 21, 2005 | 07:08 PM
427CPE's Avatar
427CPE
Ed
Ok, fair enough, but 45++rwhp??????????? Thats a bit optimistic. If those heads add that much hp by ONLY adding heads, I'm buying at almost any cost. Keep in mind, I'm at 550 lift and anything beyond is useless. As for cams, like many custom grinders, I usually call COMPETITION CAMS directly for a lobe of choice using the following data below.
blktie, strange thing. Cartek researched the very same cam you have years ago and it works great. I once used the 3722/3724 (224/228) and it worked well also. Looks like you chose a good cam.
Check out the following if interested.
To Et Performance
