My experience has not been positive. My car is a 2001 Z06. It normally lives in the Houston area and runs fine on 93 octane premium. Last summer I took it on a long cross country (5500 mile) trip and it pinged like crazy on the 91 octane fuel available in several states.
I just drove up to Canada from Louisiana and found a slight ping when using 91 octane gas also. On 93 it is a non issue. I suspect the 2 points in octane make the difference. I am considering a decarbon just as normal maintenance at 60K miles but not for ping. If there is carbon on the piston that glows hotter that the other components it could cause ping. But given how C5's are driven I have a hard time believing we have build enough carbon to cause this problem. I am more concerned with carbon on the back side of the valves causing restrictions to flow more than I am with ping. Just another $.02
I just did the Sea Foam to my 93,000m 1986 coupe. HOLY CRAP I expected some smoke, not a full blown smoke screen operation! Thank goodness I did this at work and not at home.
After it finally cleared, I closed up shop to head home. A mile down the road I started to get my foot into it. GEEZ! another smoke screen trailing me down the road. I got my foot out of it and the smoke lessened and finally stopped about five+ miles later.
The kicker is my engine actually does run smoother. I don't normally buy into snake oil products but it definately did something. Gonna try another bottle maybe tomorrow. Gotta find a witness
From: Alhambra Calismognazifornia, in the country everyone comes just to complain but won't go back home!
how bad is this smoke screen thing??? i'm thinking of doing this since i'm at about 84k but am i gonna smoke people out of their homes???
without tearing down the engine i can not be exact, but the results of using the GM product is dramatic. You pour two cans in as directed in the air intake from the PCV. Then let sit for 24 hrs and restart. At restart clear everything out of the way from your exhaust. All hell brakes loose with smoke that looks a Navy Ship's smoke screen. There is a ugly black liquid that is also exited and it is alot that you do not want to get on things.
Does it work....While I believe so and if not it is the greatest show on the start up. You should plan to change your oil after this.
I just did the Sea Foam on my 01 Z06 with 30K miles and I am getting better mileage. I do the decarb at every oil change,which is about every 5-6K miles. Snake oil....I don't know.
But I definitely enjoyed the smoke show!! As mentioned,if you haven't decarbed in awhile or ever,there will be A LOT of thick smoke,esp. when you romp on it while driving. And I do suggest you drive it and get on it hard to redline to clear it out. Don't park and rev for too long....neighbors will call the fire dept. Take it somewhere more secluded. And change your oil immediately after the decarbing!
44K will not harm any seals, etc...I talked with the cheif engineer for BG and he also put it in writing and sent it to me
Do you just get this from Auto Zone or is it a specialty item??
Do you just add it to tank of gas or is it a decarb proceedure.
Do you have to change your oil afterwards
DH
Hi,
My '02 C5 engine burns some oil and the piston slap was getting louder when cold.
I used GM Top Engine Cleaner #1050002 at ~20k miles and removed the heads a week later. The combustion chambers were clean down to the metal on the spark plug side of the chamber near the intake. This is the wall washed by the intake flow. The rest of the chamber had some deposits, as did the piston tops. The intake ports and intake manifold where completely clean of deposits or oil.
The octane requirement definitely reduced and the piston slap noise reduced.
