Gentleman,
I have a 00 vette LS1 with heads, cam headers, 430 RWHP and want to install SLP's mass airflow sensor due to the larger design of the sensor 85mm vs 75mm (97-00) and better airflow. Does the SLP come allready calibrated out of the box or do I have to have the sensor recalibrated for the 01-04 application. In addtition I have a blackwing aircleaner will I have to order the lager bellows for the larger airflow sensor?
v/r
THEYAV
i believe they come calibrated(well mine did anyway). but i did have to order the haltech 01-04 intake for it(i have a 99). since the maf is bigger the 97-00 stuff would not work.
If your replacing the MAF you should have it tuned, even if it is calibrated it will act different with everyones setup. I personally wouldn't replace it. The expense and possible tuning issues arn't worth the HP you think your going to get. I don't think 430 is enough HP to warnt the mod. I would look somewhere else for power. Given the year of your car you would be much better served with a FAST intake and TB. I seriously wouldn't touch the MAF.
