Digital Temp Display Weak
Old Aug 21, 2005 | 03:58 PM
kayakmc's Avatar
kayakmc
Default Digital Temp Display Weak
My digital display for the Dual Climate Control System fluctuates from being readabile to almost totally faded out. Is it going or is there something loose?
Old Aug 21, 2005 | 04:00 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I have the same problem. I am told it is a known issue but I do not know what the resolution is.
I'm curious to learn this as well.
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
It's going, you can have it rebuilt for $45.00
1-860-583-0629 Carl (or) caferacer1@comcast.net
I have no affiliation with this company, I'm just passing on the info I have.
Old Aug 21, 2005 | 04:10 PM
RPO_Z06's Avatar
RPO_Z06
Old Aug 21, 2005 | 10:36 PM
rws.1's Avatar
rws.1
It is a known problem.
Your choices are
1. Buy a new AC head unit form your local dealer for about $380 for the part and 4 hours labor at what ever they extort.
2. Buy a new part form Fred Beans for about $280 and replace yourself
3. Buy aused unit via ebay... about $165-175
4. Buy a fix from the forementioned repair person for $50 and do the removal/install yourself.
Basically the issue is cold solder joints. The repair specialists resolder all the suseptible contacts.
Do a search on HVAC and you should find some intructions of removal of the unit
To Digital Temp Display Weak
