Need Help With Cel Codes
Old Aug 22, 2005 | 09:29 PM
EVILNESS's Avatar
EVILNESS
Default Need Help With Cel Codes
So im driving this morning and my CEL(check engine light) comes on i logged it and it gave me two codes. P1133 and P1415 can someone please tell me whats wrong with the car to make these pop up? Anybody had to deal with these? Thanks in advance.
Old Aug 23, 2005 | 02:03 AM
EVILNESS's Avatar
EVILNESS
Anybody???
Old Aug 23, 2005 | 04:34 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
P1133 shows insufficient switching of the bank 1 oxygen sensor #1 which would be the sensor before the cats.
P1415 shows air system 1 fault
If either of these codes came up followed by an "H" then it was probably just a momentary fault, if either of these is followed by an "HC" then they are a current fault. I would try to reset them by going into manual diagnostics and pressing the reset when the DIC displays "PCM-2 codes" then see if they repeat.
If they happen to repeat then I'd have to take a guess and say that the check valve on the left exhaust manifold is stuck. the way the air system works is when you first start your car when it's cold the air pump will kick on for a minute or so and pump fresh air into the exhaust system if the oxygen sensors see this the voltage changes, then after a minute or so the air pump kicks off and the system switches to closed loop and the oxygen sensors control the AFR.
Old Aug 24, 2005 | 12:34 AM
EVILNESS's Avatar
EVILNESS
I went ahead and cleared the codes to see if it comes back if it doesnt im not gonna worry about it if it does im gonna order the check valve. I guess if that doesnt fix it ill buy the O2 sensor hopefully it will be ok. Thanks for the help.
To Need Help With Cel Codes
