Maybe it's not too hot...but people always tell me their temps are lower.
I drove from Jacksonville, NC to Charlotte,NC today and my usual (A4)tranny fluid temp was about 214 - 216 during the day. When I am in town it usually gets to 223 or so. I drive the car very gently. Is this too hot? If so, what might be causing this?
EDIT: For 1 hour of the trip my tranny temps fluctuated between 194 and 203 because the sun went down.
I don't think that is too hot, but check the intake area of the radiator for leaves,
plastic bags, etc. Be sure to check the other side of the radiator too. You have to
remove the fan shroud to check it.
I am facing the EXACT same situation. .. And I had just done my Tranny service (changed fluid and filter for A4). And IT IS considered hot, if you read other threads...
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Clayton
I recently checked mine and was totally amazed at how many leaves were stuck up there. After cleaning, there was a noticable temp drop.
Clayton
There has been a ton of threads on this subject. I made up an air hose with a 90 degree fitting to blow out the A/C condenser and the Radiator. I got over a cup full of sand, dirt, grass clippings, leaves, etc. Don't just look up from under the front of the car, since thats just the A/C condenser. The Radiator is behind it.
Okay, I've read this theory of cleaning the radiator area to lower the temps. As logical as it sounds, I can't seem to find anything stuck under my car. My temps are very high too. So can anyone shed some light on where and how to look for debris, leaves, etc. I just opened the hood looked in it, and found nothing. Went under the car, looked at the big radiator, found nothing.... Where exactly am I supposed to look ? Plz help. Thanks..
Let's make sure we are all talking about the same thing here. His post states TRANNY temps, not coolant, not oil temps...from reading some of the responses I don't think everyone is referring to the same thing..I am no expert but would hate to see wrong info get mixed up in this.
The Tranny fluid is cooled thru the radiator, unless he has a seperate after-market cooler. So there is a direct connection between the two. He didn't say what his coolant temps were, but if he's stock, I bet it's in the 195-220 range or more.
OK, as I pointed out earlier, when you look up uder the front of the car, you are looking at the A/C condenser not the radiator. The radiator is about an inch behind the condenser. To get to them from the top, you have to undo the 4 screws that fasten the plastic shroud cover and remove it. Then with an air hose or water jet clean out the debris that's stuck between the fins. (if you ever cleaned your home A/C condenser coil fins, it's the same deal) You'll be amazed at the amount of stuff that will come out. Since the Vette is a bottom breather, it picks up everything.
Radiator cools tranny fluid as well. Obviously their temperatures will reach (or try to reach) some kind of equilibrium between themselves and the outside air.
My coolant temps dropped 30 degrees or more when I cleaned out the radiator. I took it totally out though and cleaned it (and the AC condensor) with a pressure washer then with compressed air until it was spotless.
that's what I figured, but wanted to make sure.. I'll keep my trap shut next time , have not had an A4 since my F-body days,
Thanks for the responses everyone. Yup, that's about where my coolant temps are staying. My real concern was the tranny fluid. I actually has the radiator cleaned out the day before this trip, along with an oil change...so I am fairly sure that isn't the problem. The temps are a fairly consistent condition. I just became worried because so many people on here talk about tranny temps in the 180's. I have to park my car to get it that low.
You have to check the whole story on 180 oil temp reports. Many are running 160 degree thermostats and lowered cooling fan settings plus an extrenal oil cooler. That's all great if you run at the track, but for normal cruising in hot weather, what you're seeing is fine.
