Turn signal bulb replacement
Old Aug 23, 2005 | 03:28 PM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
Default Turn signal bulb replacement
Okay..I have the bulb and socket in hand...what is the trick to getting the damn bulb out of the socket?
Old Aug 23, 2005 | 03:41 PM
DidntSettle
ttt
Old Aug 23, 2005 | 04:08 PM
DidntSettle
Anybody know the trick?
Old Aug 23, 2005 | 04:16 PM
sage666's Avatar
sage666
Default Pull It Out
If you have 3057 bulbs, then just pull it straight out.
Old Aug 23, 2005 | 04:20 PM
98C5RT's Avatar
98C5RT
From: Somewhere between the Red and the Rio Republic of Texas
For the front turn signal bulbs, you have to push in and turn. Look at the replacement bulb to see where the tabs are on the base and use that as your guide. I replaced mine recently, which caused me to use a lot of patience. Good luck!
Old Aug 23, 2005 | 04:21 PM
DidntSettle
Thanks! Man...it was in so tight, I thought I might break the bulb getting it out. 3157NA
To Turn signal bulb replacement
