I had some body work and paint done to the front of my C5 this week.
I got the car back yesterday and now it has a rough and inconsistent idle.
I have a Halltech Tric intake, headers, new exhaust, etc. Could it be that if the battery was disconnected for a certain amount of time that I may have to go through the idle re-learn procedure again?
I am going to do the "Idle Relearn Procedure" this afternoon.
In that procedure there is a reference to Pop open the engine fuse block box cover and remove the two 10amp fuses from position numbers 16 & 23. Can someone tell me where the engine fuse block is?
Thats what i did when I did the idle relearn. Its next to the battery, but be warned, mine did not look like what the owners manual said the layout was. It was close and similar, and i figured it out, but it took some thinkin'
ED
