Help! Getting surging at steady throttle.
I put a Halltech Tric intake on my car a couple of weeks ago. It's a 2002 Coupe. No other engine mods. I haven't gotten any codes or trouble alerts. The car idles well, the acceleration is good, everything else good. But when I'm driving at a steady speed, on a level road, I can feel the car surge or hesitate just slightly. I was carefull with the MAF and I don't believe I damaged anything. What could cause this?
I too had that surge at cruising speed with the cruise on. Fairly level and it would sure up some then let off. I did (still) have problems with the idle. My idle on startup was fine, but once driving and coming up to stop sign, i'd engage the clutch and take it out of gear and the rpms would drop to 300 or 400 and bounce around between 400 and 600 for a while. It even shut off on me a few times. (embarrassing) I tried everyone's suggestions and didn't work. Tightened all hose clamps, "idle relearn", look for leaks. So I put the stock setup back on and it works fine. Im going to take it to a local tuner next week and see if he can diagnose what is going on. Let me know if you come up with some solution.
Ed
I had the similar problem early this week. It would hesitate upon acceleration, had irratic idling down to 400 or so and sometimes nearly stall. It also had the surging problem at constant speed.
I have the Halltech Tric as well. It turns out that one of the hose clamps loosened up and the seal re-positioned itself so that there was a gap. This caused a vacum leak.
I corrected the problem and those issues went away.
Mine has done the same thing since I put my Vortex on over a year ago. No other symptoms except a surge at constant speed, and only in OD, not third. I don't think it can be a vacuum leak because it goes away when I put the stock setup back on. I've replaced the MAF and put on a ported/polished TB (not because of this), and I have the same surge. I'm guessing that some base tuning parameter needs to be changed.
combustion is a product of spark, fuel, and air. The variables for spark will not usually make this surge effect. Fuel surge would be a pressure issue, or the lack there of.. with a 60:1 air to gas ratio, air is usually the culprit. Vacuum is usually the reason for the inbalance... the other reason is a poor design in the air flow delivery system.. that is... turbulence. If turbulence is formed in the air delivery system, fuel and air mix can not be delivered consistently.. the result is surge.
Good answer. Thanks guys for your help. I'll check it for leaks. I had trouble putting the thing together. It may have pulled loose.
