Blower motor running by itself!!
Old Aug 25, 2005 | 05:10 PM
BMG50's Avatar
BMG50
Default Blower motor running by itself!!
Hey,guys. need help!! 97 C5 with dual control head...yesterday morning i heard the blower motor running on the car sitting in the basement,so, i put the key in,cranked it,and the motor slowed down and worked like it should in all ac/heat positions...drove car and 2-3 times of turning car off,did not come on,parked it in garage,ok, left it for 30 mins., and it came back on....anybody experence this??? blower control module or control head going bad????? tia Lou
Old Sep 10, 2005 | 11:24 PM
jmfol's Avatar
jmfol
Default Blower motor running by himself
Have the same problem on my '01 C5. Still working on it...
JM
Old Sep 11, 2005 | 12:28 AM
Aggie Doc's Avatar
Aggie Doc
Recently had same problem on my 97. Common problem with blower motor run on. Have to replace. Cost for the part alone is about $1100.00. I did a temporary fix by wiring an inline fuse and switch to cut the power to the blower when the car was turned off. Worked for a while, then eventually the blower would only run on high. Send me a PM and I have the info somewhere on the Service Bullitin and wiring schematic from GM
Old Sep 11, 2005 | 12:33 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I have that. 01 Coupe.
Comes on by itself when the car is switched off and key removed - for 10 seconds and goes off. I ignore it because it does not flatten my Optima and I have other things to do.
Old Sep 11, 2005 | 06:40 AM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Is it possible that you have the stinky A/C GM fix done to your cars? Down here in the South GM installed a timer (or like item) that after the car shuts off will run the FAN for a predetermined time to dry the A/C box.
Old Sep 27, 2005 | 12:23 AM
jmfol's Avatar
jmfol
16again you're right.
From the GM 2001 Vette Service Manual."...to remove odors and eliminate the microbial growth and prevent its recurrence, the blower control package of the service kit will enable the blower to run at high speed for 5 mn.It will do so approximately 50 mn after the ignition has been turned off if the A/C compressor had been engaged for 4 or more minutes prior to shutting down the engine. By doing so the evaporator case and core are dried out, reducing the cjances of A/C odor."
Seems to work OK on mine...
JM
Old Sep 28, 2005 | 12:03 PM
TopCat's Avatar
TopCat
Default Me Too!
JM
Not so fast......I know I don't have the timer on mine. Guess what....MINE DID THE SAME &#%*&$%* THING YESTERDAY on a '97, no less. Is there a bug in the computers to make this happen on 9/27/05?!?!? To boot, my ex-girlfriend 'keyed' the car. (Thought the blower might be my 'baby' crying b/c the ex hurt her )Damage - $3500 according to the first estimate
No more wives, live-ins, etc. for me!!!!! By the time I'm done with lawyers, etc., I'll have spent enough to get a used Z06!!! (and still keep my C5).
Ah hell, it's only money. Now I'll be able to get all the tricks for the vette, too. Any suggestions for a paint/body shop near K-ville.
Let me know what the fix is, too!!!
To Blower motor running by itself!!
