headlight popping back up on switchoff
Old Aug 25, 2005 | 10:50 PM
catfish2's Avatar
catfish2
Default headlight popping back up on switchoff
when I turn my lights off the driver's side pops right back up about halfway. I can turn the manual **** and it will go back down but the next time you go on and then off it does the same thing again.
Old Aug 26, 2005 | 06:35 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
See GM Service Bullentin #00-08-42-002
You can replace the actuator motor or use the fix in the service bulletin which will install washers at the stops.
Old Aug 26, 2005 | 06:50 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Read
http://forums.corvetteforum.com/show...ght&forum_id=1
To headlight popping back up on switchoff
