Need help lowering C5
Old Aug 28, 2005 | 06:56 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I got 5/8 x 7" bolts w/locking nuts for the rear,drilled out the washers & bushings so they fit the 5/8 bolt,so you don't have to cut the bushings.The front I took the bolt out and put a piece of rubber between the A-arm and leaf spring.It rides pretty good and looks alot better.The back is alittle bouncy.
Old Aug 29, 2005 | 06:35 PM
allaboutdaz's Avatar
allaboutdaz
if lowered to the max of the stock bolts will it need the alignment need to be done??
i need to know because i am running 20" wheels front and back and dont want to kill the tires
thanks
Old Aug 29, 2005 | 08:47 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
thanks
It is suggested, but some people do not and have no problems.
Old Aug 29, 2005 | 11:04 PM
craigo's Avatar
craigo
From: "Second place is just the first loser" Edmond, Oklahoma
I did exactly what this thread suggested and have had ZERO ride issues after cutting the bushings - i don't see how those hard black things could soften the ride anyway..........just my experience - it works for me and worked well. Your choice of shocks is what determines your ride.......just my opinion and experience...... I tried it both ways.
Old Aug 30, 2005 | 03:01 AM
allaboutdaz
thanks for the reply any others lower car with out alignment?
Old Sep 14, 2005 | 11:09 PM
Richie Carbone's Avatar
Richie Carbone
I lowered mine on Sunday on the stock bolts, the handling is sloppy now. Getting it aligned tomorrow.
