AC Light
Old Aug 27, 2005 | 02:31 PM
DBRASUE's Avatar
DBRASUE
Default AC Light
I have noticed that my A/C light blinks once in a while. The outside air temp registers 31 degress! I did some research and found out that my sensor may be bad. Could this be true? and where is this sensor located? Once the temp register reads above 40 degrees the light stops blinking (stays on) and the A/C again works fine. Any help is sure appreciated!
Old Aug 27, 2005 | 03:14 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
The AC compressor won't come on when it thinks the outside temp is below freezing. Sounds like your outside Ambient Air Temperature Sensor could be bad. It's located on the lower radiator support. Just follow the wire from your underhood light. When you see where that plugs in, the Temp Sensor is below that. You disconnect the harness. The sensor is just push into a small hole on the radiator shroud. You should be able to just pull it out. Be sure and install the new one in the same position as the old one. Part of it stays on one side of the shroud while the other part goes on the outside of the shroud.
jeff
Old Aug 27, 2005 | 06:04 PM
DBRASUE's Avatar
DBRASUE
Thanks for the quick responce Jeff! Soon as monday rolls around I'll get a new sensor. Going out now to remove the old. Again...thanks!
Mike
Old Sep 1, 2005 | 12:56 AM
Der Flieger's Avatar
Der Flieger
Default Outside air sensor
When mine went ****-up, I pulled it out for replacement and found the plug had a corroded-in-two pin, so had to replace the plug as well. If you have that problem, I have a good part number for the plug. It cost more than the sensor.
To AC Light
